Oceanic's TT01E Touring
Re: Oceanic's TT01E Touring
Cool!! I'm waiting for my ESC and motor from Hobby King before starting my build too.
When Kelvin's Gold edition TA05 comes together, let's all hit the tarmac track together.
RCGolf- Crawler
RCGolf wrote:Cool!! I'm waiting for my ESC and motor from Hobby King before starting my build too.
Sure bro
Ahhhh! Nothing better than the smell of a new RC kit
Looks like I need to get onroad tires for my TT01 Fairlady drifter so I can join the road-fun.
Cool ! Some of the parts need hop-up if you are using brushless motor. The shaft and the motor mount.
When building , it is advisable to apply the tamiya AW(anti-wear) grease on the gears.
wow wow wow , looks like going to have a fierce races...........
kelvintan_hc- Crawler
RTECH wrote:Cool ! Some of the parts need hop-up if you are using brushless motor. The shaft and the motor mount.
Yes sir noted.
Great looking shell indeed!
Were the wheel arches pre-cut already? (On my DF03RA they are, which is fantastic as it is hard to get them nice and round)
thank you thank you...
newbie work, not perfect.
the wheel arches is not pre cut.
Bro your workmanship very good
kelvintan_hc wrote:Bro your workmanship very good
Thanks but its far from good. Far looks ok, go near see all mistake.
Very, very nice with the lights.
Body posts need shortening, then its ready for playing it seems!
Yea, just cut off those long post. You can extend it later on if you change to other shell.
Before you do that, i think you need to lower the shell a bit so that the aerodynamics of the shell can take into effect.
Hi oceanic wht servo u use for your tt01, coz I used bluebird servo cannot fit in my TA05
kelvintan_hc wrote:Hi oceanic wht servo u use for your tt01, coz I used bluebird servo cannot fit in my TA05
im using hitec. its a standard size servo
oceanic wrote:kelvintan_hc wrote:Hi oceanic wht servo u use for your tt01, coz I used bluebird servo cannot fit in my TA05
thks bro , will go look out for that
» [Touring / On road] 14 June 2015 0900hrs - Touring, mini, and more @ 60 Punggol East
» [Touring / On road] 05 Apr 2015 0900hrs - Touring, mini, and more @ 60 Punggol East
» [Touring / On road] 26 Apr 2015 0900hrs - Touring, mini, and more @ 60 Punggol East
» [Touring / On road] 05 Jul 2015 0900hrs - Touring, mini, and more @ 60 Punggol East
» [Touring / On road] 02 Aug 2015 0900hrs - Touring, mini, and more @ 60 Punggol East
