Slow's Jeep Wrangler Build photos - AX10 with custom made scale chassis
Post by boolean21 on Thu 25 Aug 2011 - 13:03
Posting on behalf of Slow aka Slowlee
Here's the photos of Slow's Jeep Wrangler YJ build.
It's based on Axial AX10 parts mounted on a custom frame.
Enjoy!
AX10 Parts
Custom made chassis
Body mounted on the chassis
Re: Slow's Jeep Wrangler Build photos - AX10 with custom made scale chassis
Post by n4smw26 on Thu 25 Aug 2011 - 17:42
Nice one... How I wish I got equipment to fabricate something like that..
Post by slow on Thu 25 Aug 2011 - 21:36
I like the Jeep Wrangler, but cant find CC01 with that body.
So, i took my Axial AX10 to convert it to scale ride.
The wheelbase is only about 255mm. not like Axial Dingo at 290mm wheelbase.
So need to do a chassis.
So i shop for my raw material, hardware, order parts... ... ...
I took about 1 month to do it. Using my lunch time about 35min to do.
Post by boolean21 on Thu 25 Aug 2011 - 22:59
this is what i call... PASSION! nice....
Post by RTECH on Thu 25 Aug 2011 - 23:05
slow wrote:I like the Jeep Wrangler, but cant find CC01 with that body.
Suspect You sure you only use your lunch time to do it?
Post by slow on Fri 26 Aug 2011 - 19:00
[/quote]
Suspect You sure you only use your lunch time to do it?[/quote]
Ya Man
You are right man, some time i went to work early, got about 30min to work on it also Razz
