by boolean21 Yesterday at 23:14
by boolean21 Yesterday at 23:13
Boolean21's AEV Jeep Brute 1/10 scratch build
Page 2 of 4 Previous  1, 2, 3, 4  Next
Re: Boolean21's AEV Jeep Brute 1/10 scratch build
Post by Wrigleys on Wed 31 Oct 2012 - 11:22
Yes la! Can't wait for it to hit the trail.
Post by RTECH on Wed 31 Oct 2012 - 19:19
bounce Looking good.
Post by boolean21 on Sat 29 Dec 2012 - 1:39
some updates...
did up bit by bit over the past 2 months...
added a roof to the front cab...
roof after sanding...
more putty to fill in the gaps...
touching up the front fender areas...
more putty and sanding....
mocked up on axial axles, junfac rims, ripsaw 1.9 tyres.... to gauge the fender flares size....
that's all for now.... Smile
more work to be done... Very Happy
thanks for looking! Smile
Post by Wrigleys on Sat 29 Dec 2012 - 1:45
Alright! Taking shape well! So when can I collect? hahahaha Laughing
Post by laneboysrc on Sat 29 Dec 2012 - 8:03
Wow, this is becoming very nice! Love your styrene work!
Post by oceanic on Sat 29 Dec 2012 - 9:36
Still the front cab. When finish? Wait till hair all white liao.....
Post by RTECH on Sat 29 Dec 2012 - 16:47
Good things have to wait.......
Post by boolean21 on Sat 29 Dec 2012 - 17:07
Thanks bros...
Hope it will turn out well.. Very Happy
Post by kelvintan_hc on Sun 30 Dec 2012 - 17:45
Nices
Post by boolean21 on Tue 8 Jan 2013 - 23:58
some updates....
checked and prepared the artwork for the panels on the computer...
cut out the panels on stickers....
pasted the stickers onto the styrene...
traced and cut out the panels...
next, pasted the stickers for the second layer of styrene...
the second layer is to add some details to the panels....
traced and peeled off the stickers...
sticked the "additional layer" onto the base panels...
glued up the bed....
mocked up the bed with the cab...
mocked up the body with 1.9 wheels and tyres...
thats all for now.... Smile
next up will be sanding, sanding and more sanding for the bed.... Very Happy
Post by wyetuck88 on Wed 9 Jan 2013 - 0:46
looks good!!! flower
Post by boolean21 on Wed 9 Jan 2013 - 8:14
Thanks bro. Smile
Post by laneboysrc on Wed 9 Jan 2013 - 10:01
Very nice, and thanks for showing the build steps with the stickers. You should patent this method as "half-CNC" Very Happy
Post by boolean21 on Fri 18 Jan 2013 - 0:12
after some nights of midnight oil burning....
managed to do up the fenders....
below are some progress photos taken ...
sanded the corners of the bed a little...
traced the fenders onto the styrene and cut out the pieces...
then joined up the fenders...
sticked the fenders onto the front cab and the truck bed...
added some details of the door hinge as well as the door handles....
filled up the holes on the fenders....
Post by laneboysrc on Fri 18 Jan 2013 - 8:38
Wow, looks magnificent! Thanks for sharing the build progress!
Post by boolean21 on Fri 18 Jan 2013 - 8:44
laneboysrc wrote:Wow, looks magnificent! Thanks for sharing the build progress!
Thanks bro!
Post by babyboy on Fri 18 Jan 2013 - 13:54
Boolean, you can use triangle strip to strengten your bed joint. It will look more conform to the bed. Whats the total weight of the body?
Post by boolean21 on Fri 18 Jan 2013 - 14:07
babyboy wrote:Boolean, you can use triangle strip to strengten your bed joint. It will look more conform to the bed. Whats the total weight of the body?
ya bro, wanted to use triangular rods, but can't find them.... so used square rods instead....
either will fill and sand it... or leave it like that... depends on how much midnight oil left... Laughing
didnt weight the body... but it's still considered light... for now... Smile
Very Happy Very Happy
Post by boolean21 on Thu 31 Jan 2013 - 22:13
Some updates...
some work done over a few nights...
Ordered an Axial 27T motor for the Brute...
fixed up the spare venom creeper transmission that i had left from the 6x6 build... Smile
mounted the tranny on the aluminium brackets and test fit under the cab...
needed some 60mm shocks... and found a set of spare shocks from my OTA-R31...
so built it up and see if it is usable... Very Happy
i had also mounted the shocks upside down to save some trouble in additional modifications to fit... Razz
the 60mm shocks are still too long... and causing the drive shaft angle to be very steep...
so... had to drill a few more holes to shift down the transmission a little as well as slant the shocks so as to lower the gap between the tyres and the fenders....
Drive shaft angle looks better now... although still a little on the extreme... Very Happy
once the body weighs down the suspensions... the angles should be good to go... Smile
Here's how the AEV Jeep Brute looks like now...
Till the next updates......
Post by wyetuck88 on Fri 1 Feb 2013 - 0:28
Nice.... What colour are you planning to put on that lovely jeep?
Post by boolean21 on Fri 1 Feb 2013 - 0:42
wyetuck88 wrote:Nice.... What colour are you planning to put on that lovely jeep?
Thanks bro..
Should be going for mustard yellow....
Smile
Post by laneboysrc on Fri 1 Feb 2013 - 8:28
Looking really good! Needs some lights though Very Happy Very Happy Very Happy
Post by boolean21 on Fri 1 Feb 2013 - 10:55
laneboysrc wrote:Looking really good! Needs some lights though Very Happy Very Happy Very Happy
thanks bro. Smile
i happen to know a lighting specialist in the group...
his nick is laneboys something... Very Happy
Post by babyboy on Fri 1 Feb 2013 - 20:41
Very Nice! Cant wait to see it at the trails!
Post by boolean21 on Fri 1 Feb 2013 - 23:20
babyboy wrote:Very Nice! Cant wait to see it at the trails!
thanks bro!
Post by boolean21 on Sat 23 Mar 2013 - 2:18
found some midnight oil to burn.... Smile
some updates on the brute...
did up the links, bead locked the ripsaw tyres on junfac 1.9 rims
fitted the drive shafts to the venom creeper transmission...
some midnight posing shots... Razz
not to forget our all time favourite "dog peeing stance"...
Post by laneboysrc on Sat 23 Mar 2013 - 7:20
Thanks for the progress update, was missing it already Very Happy
Looks like you are on the home stretch already, looking very good!
Post by oceanic on Sat 23 Mar 2013 - 8:03
I forgot u still have the brute project... Evil or Very Mad
Post by boolean21 on Mon 8 Apr 2013 - 21:08
some updates on the jeep brute project...
did up the bed and the wheel well...
test fitted into the bed....
covered up the sides...
added some "texture".....
test fitted again...
next was to mount up the RC4WD Trail Finder 2 side bars...
donated by master Liew....
fitted perfectly...! love them! Smile
thanks!
Post by oceanic on Mon 8 Apr 2013 - 21:10
Swee swee!
Dont drag so long leh....
