New Landy in the making
my humble landy is almost done...
lostdriv3r- Crawler
Re: New Landy in the making
Good Work! You might wanna find ways to sit the body lower.
Wow...nice looking landy.
Very nice indeed. Camel yellow? Just something to take note... you really need to bring down the body as per wrigleys advise. The D90 is very top heavy. It look nice but unless your chassis weight a ton, you will have a lot of roll over. As you will tend to put scale accessories on the roof rack. To help counter this is wheel weight. It helps somewhat and wider tyre. You are using ripsaw tyre... hopefully will balance it out. Make sure you use a screw to hold your side mirror. Glue will not hold. Last but not least have fun and join us for extreme trail.
Wekcome to the Landy family.
Yea, am using Camel yellow... The body feels too heavy for this dingo chassis. Will probably need to make more adjustments after a few (dry) trails. The only thing left now is the "driver"... The current figures I have now are either too big or too small...babyboy wrote:Very nice indeed. Camel yellow? Just something to take note... you really need to bring down the body as per wrigleys advise. The D90 is very top heavy. It look nice but unless your chassis weight a ton, you will have a lot of roll over. As you will tend to put scale accessories on the roof rack. To help counter this is wheel weight. It helps somewhat and wider tyre. You are using ripsaw tyre... hopefully will balance it out. Make sure you use a screw to hold your side mirror. Glue will not hold. Last but not least have fun and join us for extreme trail.
lostdriv3r- Crawler
» Zax's making of a Beast. MAN KAT1 8x8.
» wrigleys' SCX10 Landy Land Rover D90 build
» Teck D90 landy built
» Questions on Landy bumpers and SCX10 rails protruding
» Liew's CC01 landy d110 RSOV build
