Noob needs help please
Hey guys, i am a complete noob at all this stuff, although i am not completely hopeless. I have a hsp bushless buggy, i run some 2s lipos in it with deans connectors and i have an imax b606 charger. I want to get into trails and crawling and mudding. But i have no idea. Ive been told th the axial wrait ir trail honcho will suit me well, but what cinnectors do they have. As i cant afford to buy new batteries, and i dont have a soldering iron,
Help pleease hahah
Help pleease hahah
Nicko1508- Crawler
Re: Noob needs help please
hi bro, great to see u here....
u can simply get the deans to tamiya adaptor and you can use the deans on the rtr wraith or the honcho...
Sick man thanks. Look about 10 bucks on eBay. Would i need female.or male adapter?
Nicko1508- Crawler
Nicko1508 wrote:Sick man thanks. Look about 10 bucks on eBay. Would i need female.or male adapter?
should be cheaper than that, check out your local rc shop to see if they have them over there.
batteries usually comes with female connectors so that they will have lesser chance of shorting, check out your lipos to confirm, they should be female deans...
the axial rtr comes with male tamiya style plug... so you'll need a male deans to female tamiya adapter...
i'll try to upload a photo later of the adapter i'm using...
Awesome thanks alot. Is the adapter just easier then soldering?. Also I'm stuck between the wraith and honcho, I'm going to be using it for a little bashing and little jumps, but I got some creeks and rocks in te bush beside my house, what would you recommend out of the two?
Thanks again for all your help
Nicko1508- Crawler
http://www.amazon.com/gp/aw/ol/B001GT18WI/ref=aw_d_ol
That looks about right
Nicko1508- Crawler
Hi bro, the wraith rtr has got 2.2 tires, would be better for rocks... but for trails, both are great crawlers...Nicko1508 wrote:Awesome thanks alot. Is the adapter just easier then soldering?. Also I'm stuck between the wraith and honcho, I'm going to be using it for a little bashing and little jumps, but I got some creeks and rocks in te bush beside my house, what would you recommend out of the two?
most importantly, follow your heart... buy both!!
Nicko1508 wrote:http://www.amazon.com/gp/aw/ol/B001GT18WI/ref=aw_d_ol
ya bro, that's the one... i just checked and confirmed my adapter.
Awesome thanks so much for all your help!!!!!!!!
Nicko1508- Crawler
no worries bro...Nicko1508 wrote:Awesome thanks so much for all your help!!!!!!!!
do remember to post some pics in the member's rigs section when you got your crawler!
you can also post some pics of your buggy too...
Will do
Nicko1508- Crawler
Our friendly neighbourhood Boopek have save the day again!
Thumbs up!
Thumbs up!
well if need be i can change the connectors.. i have all the soldering equipment.
AAmazingly ii found an adapter that is deans mail to tamiya female connected to my old charger. Will that work on my axial honcho which I've decided to get. Also how do you go about water prpffing the trail honcho
Nicko1508- Crawler
Hi bro, yeah, that will work....Nicko1508 wrote:AAmazingly ii found an adapter that is deans mail to tamiya female connected to my old charger. Will that work on my axial honcho which I've decided to get. Also how do you go about water prpffing the trail honcho
For waterproofing, easiest way is to balloon the receiver and the light unit small pcb, grease the output shaft of the servo, and for the esc, either put it into a container and seal it up, or like what some of us do, waterproof it using NEUTRAL CURE SILICONE.
Can check out some of the threads I post here on waterproofing...
I'm going to try and water proof my buggy just for practise. I have plenty of small plastic container and some marine grease.what does balloon the reciever mean?. Do I cut wholes in the plastic container for the wires? Then seal them off with something?
Nicko1508- Crawler
hot glue? got plenty of that shit, what do i cover on the esc
Nicko1508- Crawler
just like the wholes in the plastic around the chords
Nicko1508- Crawler
Put the esc in a container, drill some holes to let the cables out, and seal up the container and holed.... Check putt the thread where I did the waterproofing initially, the one with a container...Nicko1508 wrote:just like the wholes in the plastic around the chords
» hey there all,,, forgive me if this is in the wrong place, but I'm a noob
» Noob question on crawler with speed
» Noob question on higher voltage 3s lipo systems and need for BEC? And best kva motor for crawling??
