Axial EXO 1/10 Terra Buggy
+6
10 posters
Page 1 of 2
Page 1 of 2 • 1, 2
bro Harakiri just poisoned me with this
http://www.axialracing.com/ftp/exo/index.html
Check it out!
Buy buy buy!
FEATURES:
Adjustable Motor Mount
Our patent pending adjustable motor mount included with the EXOâ„¢ features a two piece design that allows you to easily set your gear mesh with an adjustment screw providing the ability to achieve a perfect fit. A set screw is used to securely lock the two piece motor mount in position. The two piece mount is also keyed for proper alignment and strength.
Standard 32 Pitch Gears
The EXOâ„¢ utilizes standard 32 pitch pinion and spur gears to provide more tooth surface area for durability and efficiency to put its power to the ground!
Three Oil-Filled Differentials
Three, silicone oil-filled differentials transfer power to all four wheels and because they're oil-filled they can be fine tuned with optional oil. Each differential features four sintered gears housed in compact differential cases. This also allows the EXOâ„¢ to use compact and streamlined bulkheads for reduced weight, meaning less rotating mass for higher performance.
Durable Driveline Components
The stub axles are held in place by two bearings, an outer small bearing, and a large inner bearing. The larger inner bearing increases durability and stability. The steering pins are titanium nitride coated for less wear and durability. The axle is mated to a standard 12mm cast aluminum hex hub.
Quick Release Battery Mount
Our patent pending quick release battery mount is easily adjustable to fit any battery pack. The flexible rubber straps are connected to a hinge on one end and the other contains a pin that keys into a composite plastic latch that keeps your battery securely in place. There's also an integrated "lift assist" mechanism which puts the battery in the best position for removal. The lower plastic end plates are adjustable which allow you to fit any battery pack, and in most cases, two batteries will fit standing on edge. The motor position is centered lengthwise and battery is positioned towards the center for balance and stability.
Integrated Light Bar
Brighten up your night time driving session! The integrated light bar holds up to five LED lights and features clear plastic lenses and three styles of mesh covers - plain, Axial and officially licensed PIAA covers! (LED lights not included)
Protective Skid Plate Bumpers
The front and rear bumpers are hinged which allow them to flex upon impact, protecting the EXOâ„¢ from crash damage. Aluminum skid plate inserts add an extra level of protection and feature an embossed surface for added style.
Rear Tail Lights
The built-in rear diffuser/wing has embedded rear marker light buckets for up to four LED tail lights (LED lights not included).
2.2/3.0 Raceline Renegade Wheels
Raceline is by far the most popular wheel for extreme duty off-roading. Their ability to stand up to the abuse demanded by the full-size racer and their show quality finish is second to none. The officially licensed Raceline Renegade gives the EXOâ„¢ that authentic racing look as well as providing the strength to handle whatever you can dish out!
Hankook Dynapro MT Tires
The EXOâ„¢ features realistic, officially licensed Hankook Dynapro MT tires that perform as good as they look. The front tires are narrow (34mm) which help the EXOâ„¢ navigate the terrain while the rear tires are wide (41mm) putting the power to the ground with enough traction to keep the EXOâ„¢ firmly planted. Internal ribbing helps reinforce the sidewall to prevent it from folding over which keeps the tires working at peak performance.
Licensed Griffin Radiator
Realistic fan blade and grille cover details.
Adjustable Suspension
Threaded shock bodies, multiple shock positions and adjustments for toe, kickup (rear), camber, roll center and ackerman allow you to fine tune your suspension for high performance.
High Quality Components
We've chosen a variety of parts that keep the EXOâ„¢ durable and performing at a high level. These include steel turnbuckles, steel dogbones, steel outdrives, captured stainless steel hinge pins, full ball bearings, titanium nitride coated shock shafts and steering pins and a sintered steel pinion gear.
Tuned Shock Springs
Finding the right spring rate can be tough. Axial made it easy for you by including what we found to be the right balance of high speed and harsh terrain handling. The spring rate we've chosen keeps the EXOâ„¢ on course and ready for your next obstacle!
High Quality Steering System
The EXO utilizes steel steering posts, an aluminum steering rack, and an aluminum servo saver retaining system with captured bearings to keep you pointed in the right direction. The entire steering system also leans back 10 degrees to match the front kickup which eliminates all bumpsteer.
Wire Routing
The chassis has plastic routing clips throughout which helps keep your receiver and servo wires snug and away from moving parts which could shred the wires.
Waterproof Receiver Box
Our waterproof receiver box keeps your radio gear protected from the elements and with integrated wire management, it keeps the receiver leads organized and away from moving parts.
Patent Pending ESC Clip
We include three ESC mounting plates. Securely clip in your Castle SV2, or Novak Havoc SC ESC's with our patent pending ESC mounts. Running something different? Then use the included universal servo mount plate and standard servo tape.
Realistic Scale Details
The EXOâ„¢ features a variety of fully licensed, realistic features including a V8 Turnkey engine, a Fuel Safe fuel cell and an interior body set with four Corbeau race seats.
Robust Molded Roll Cage Design
The cage closely resembles what you'd find on 1:1 vehicles making this a strong and proven tough design that keeps the EXOâ„¢ well protected.
4mm Aluminum Chassis
The 4mm center chassis is made from 6061 aluminum for durability and features recessed pockets to lower the center of gravity.
Ground Clearance
The chassis tub is tapered to give you an extra 1/2" of ground clearance.
Double Shear Mount
The captured double shear shock mount features an aluminum plate that keys into the molded cage for added strength.
Check it out!
Buy buy buy!
FEATURES:
Rear Tail Lights
Tuned Shock Springs
Wire Routing
Ground Clearance
Double Shear Mount
Last edited by boolean21 on Thu 3 Nov 2011 - 21:24; edited 4 times in total (Reason for editing : More details updated!)
Re: Axial EXO 1/10 Terra Buggy
Axial just announced this yesterday.. Another poison!!! Anyway the new dingo kit doesn't come with beadlocks but quite a chio set of rims.. Buy! Buy! Buy!
http://www.rpphobby.com/product_p/ax90015.htm
Retail price and some photos can check here.. .. .. .. ..
And Soooo... ... .. .. .. ..
Who is Buying.. .. .. .
slow wrote:And Soooo... ... .. .. .. ..
Santa Slow... i also want this for Christmas....
Just want to get df03ra , then poison by Hpi 1/12 mini ! Now axial evo ! Tmr have to ask my boss got OT ?
Liew wrote:Just want to get df03ra , then poison by Hpi 1/12 mini ! Now axial evo ! Tmr have to ask my boss got OT ?
Yo Bro Liew.. ..
Luckily we hevent buy HPI 1/12 mini Trophy, We don buy the HPI 1/12 mini Trophy liao la..
He.. .. he.. ... we get the EVO together la.. .. ..
This force is strong again liao... ... ..
Buy BUy BUY buy buY??????
Ans its still BUY
Ans its still BUY
anyone found pics of the internals?
wanna see where the motor is placed... and the transmission position....
likely in the front area below bonnet?
and battery put where ah.... like so little space...
nice nice....
nice nice....
Not much information at the moment lei
Wow! looks a bit like wraith but more sleek and fierce!
Now Darth Maul have a new apprentice, boo skywalker. Looks like he have fallen into the hands of the dark side..
RTECH wrote: Wow! looks a bit like wraith but more sleek and fierce!
boo always stands on the bright side...
wah this buggy so freaking chio! die liao lah...
Ha......go with the force follow the journey to the dark side of buy buy buy. buy hpi buy axial
Harakiri- Boss
Harakiri wrote:Ha......go with the force follow the journey to the dark side of buy buy buy. buy hpi buy axial
The evil Darth Maul strikes again !
Wa Liao.. .. .. ..
Keep Poisoning... ... ..
Me kana Poison deep deep liao.. ..
now i know liao.... the seats are "half" height.... so the stuffs are still below there....
i thought if all 4 seats are like wraith full size seats, then where the stuffs below go...
I think only the SMURFS can fit in the sit. Wahaha!!!
RTECH wrote:I think only the SMURFS can fit in the sit. Wahaha!!!
doraemon!!
Full detail can be seen here
nice buggy... poison... ok, who taking order???
rcming- Crawler
rcming wrote:nice buggy... poison... ok, who taking order???
Can see that you kanna poisoned liao!
Haha
So when are we ordering me buay tahan liao......
Harakiri- Boss
really damn nice... oh man..
Page 1 of 2 • 1, 2
» [BUGGY VIDEO] Axial EXO Terra Buggy LOSI TLR22 short course trucks @ Segar Track RC Offroad Adventures
» New products.
» New axial exo terra buggy rtr
» Boolean21's Axial EXO Terra Buggy
» Wrigleys Axial Exo Terra Buggy Build
» New products.
Page 1 of 2
