In total there is 1 user online :: 0 Registered, 0 Hidden and 1 Guest None
Boolean21's AX10 Proline Tuber updates
Some updates on my AX10 Proline Tuber...
tore up the transmission and coat the internals with marine grease... and installed the spur gear cover...
next up would be installing the R1 axles onto the tuber...
here's some photos of the internals... haven't mud the AX10 before... everything still looks clean clean...
Re: Boolean21's AX10 Proline Tuber updates
after motivated by bro wrigleys's ax10 tuber updates... i decided to spend the evening to continue my ax10 tuber rebuild too...
replaced by 120mm shocks to 90mm topcad piggy back shocks...
drive shafts to topcad wraith drive shafts, sleeved the bolt points with heat shrink...
gmade r1 axles installed... and plucked the gmade rims from my xr10 and use on the tuber instead...
most of the links are custom made using 4mm threaded rods, will be sleeving them with carbon rod later on...
thats all for today...
woohoo long time no see! good to see it back.
thanks for your motivation... else i think the poor girl (betty wearing tube) will still be on the shelf...
took out my AX10 tuber for dusting.... and at the same time...
added a servo and sleeved all the links with heat shrink....
here's some photos...
» Wrigleys's AX10 with ProLine Tuber
» [VIDEO] 8 Trucks mudding: Timberwolf Ford F350 Proline Tuber Intergy tuber Wraith MAN Unimog U300
» Proline Tuber Bolt-On Chassis
» [Video] 12 trucks running: Unimog, Honcho, Tundra, 4x Wraith, 3x Defender, Ford, AX10 Tuber
» [Video] 11 trucks: RC Trail adventures Defender D90 Clod Buster AX10 Integy Tuber Man Wraith
