In total there are 2 users online :: 0 Registered, 0 Hidden and 2 Guests :: 1 BotNone
Which kit for Defender D90?
Can Check with u guys what kit u all using for the defender? What's the scale, price n lastly where can i get it? Thanks
trust- Crawler
Re: Which kit for Defender D90?
trust wrote:Can Check with u guys what kit u all using for the defender? What's the scale, price n lastly where can i get it? Thanks
hi bro,
the defenders run on many different chassis..
below are some of the chassis used.
Axial SCX10 Dingo, Honcho, Axial AX10 with custom frame, Tamiya CR01, Tamiya CC01, Custom chassis, RCmodelex Defender chassis...
Which chassis is good for newbies? N what's the price range?
trust- Crawler
trust wrote:Which chassis is good for newbies? N what's the price range?
for the defender shell to fit, you'll need some form of customization... it's not a buy and run if you want to get the defender.
lesser customization work if you go for RC4WD Gelande chassis or RCModelex Defender chassis, both are more expensive..
alternative would be to get the axial scx10, but some customization will be required for the defender body to fit.
you can check out the price from the online shops...
Oh ok thanks a lot for ur advices. For the Rc4wd gelande chassis , the rcmodelex defender n axial Sch where can I get it? Only thru online or where can I get it locally?
trust- Crawler
these are 1/10 scale...
where are you from btw, from Singapore or overseas?
Hi I from Singapore. Hahaha... Which r/c shop sells those chassis? Or which online web?
trust- Crawler
trust wrote:Hi I from Singapore. Hahaha... Which r/c shop sells those chassis? Or which online web?
if in Singapore, you can pop by our meets to check out the different makes and models before deciding on the rig to get...
so far, towerhobbies has the most attractive price after additional discounts...
boolean21 wrote:these are 1/10 scale...
wat about you??
Marpek wrote:boolean21 wrote:these are 1/10 scale...
wat about you??
I'm from overseas of course!
Different time zones from you guys....
» defender 110 of rcmodelex and defender 90 of rc4wd on the rails
» Topcad Defender D90 kit
» WTB Defender D90 Snorkel
» Defender D110. Anyone has it?
» Defender video
» Defender video
