Glue-ing tyres
Glue-ing tyres
any idea whether i can use Shoe Glue to glue the tyres to the rims?
need to glue the tyres for the df03ra... rear tyres coming off when sharp cornering on tarmac...
Re: Glue-ing tyres
DF03Ra not really supposed for Tarmac, thus glueing not required mah...hahaha.
Can try super glue, for trail can hold, but dunno for touring...
Re: Glue-ing tyres
oh... means for rally no need to glue? on sand and grass ok without glue? then I will just leave it liao...Marpek wrote:DF03Ra not really supposed for Tarmac, thus glueing not required mah...hahaha.
Re: Glue-ing tyres
shoe glue can.. works well, and no need scared it'll come off.. super glue will disable the rim for use for other tires when the mounted tire is worn out.. shoe glue can just cut out.. that's wat i used for my TT-01 rally back then.
was running a 5700kv mamba motor, no problems with the tire coming off.. and can change tire when tire worn out or torn..
just gotta make sure its the brown and super sticky ones, let them set for about 3-4 days before using the tires.. oh yes, the tires must be washed clean before glueing, otherwise the glue might not work well and u'll get unbalanced tires..
Re: Glue-ing tyres
qks57 wrote:shoe glue can.. works well, and no need scared it'll come off.. super glue will disable the rim for use for other tires when the mounted tire is worn out.. shoe glue can just cut out.. that's wat i used for my TT-01 rally back then.
thanks for the info bro.
Re: Glue-ing tyres
qks57 wrote:
just gotta make sure its the brown and super sticky ones, let them set for about 3-4 days before using the tires.. .
Seriously 3-4 days? I normally use CA. just spot glue around the rims.. Stick real gd, and not that of hassle to remove if need be..
n4smw26- Crawler
Re: Glue-ing tyres
yep, 3-4 days for the shoe glue to fully set to prevent any mishaps.. lol..
depending on what the tire is used for also lah. cos for me, most of those tires i glue are rubbers or rally tires, which r either used for burning(drifting) or rally with a 5000+kv motor.. hence its a must to let it set..
i didn't take advice back then, and used the tires the next day, and off they came.. haha...
» WTB: 1.9 Tyres
» Replacing Glued tyres?
» WTB - scale wheels and tyres
» CC01 tyres & alternatives
» wts GMADE beanlocked rims and tyres!
