In total there are 3 users online :: 0 Registered, 0 Hidden and 3 Guests :: 1 BotNone
Cheap and good lipo
RJNG
Page 1 of 2 • 1, 2
Cheap and good lipo
Hi Guys, Any good and cheap lipo to intro that can fit in CC01 chassic? Thanks
RJNG- Crawler
Re: Cheap and good lipo
zippy 4000mah lipo.. its in stick pack form, can fit in no problem..
yeah racing 4000mah stick pack lipo also can work..
qks57 wrote:zippy 4000mah lipo.. its in stick pack form, can fit in no problem..
Thanks bro, where can i get these 2 brands? What will be the price? Cheers
RJNG- Crawler
http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=235&LiPoConfig=2
n4smw26- Crawler
can try turnigy 4000mah too... also from hobbyking.... but their shipping is long..... even when you pay for the expedited shipping.... no choice la.... cheap ma....
n4smw26 wrote:http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=235&LiPoConfig=2
Thanks bro, the price at hobbyking really good. Will be buying from there, eyeing on the 5000mah. but so many type. Usually which size should we get? I know cc01 can't take hardcase type, right?
RJNG- Crawler
RJNG wrote:n4smw26 wrote:http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=235&LiPoConfig=2
I think 5000mah hard case might be too big... 4000mah should fit....
Wait for other cc01 owners to reply...
http://www.hobbyking.com/hobbyking/store/__8357__ZIPPY_Flightmax_4000mAh_2S1P_25C_Car_Lipoly_ROAR_Approved_.html
this is the particular one i got and i'm using.. fits perfectly in M03, same size slot as CC-01.. cos its in stick pack and hardcase form, so its great..
the yeah racing is more pricey, about 80 bucks a pc.. can get from streetrevorc at bukit batok industrial area Midview Building.. but its not hardcase lah..
qks57 wrote:http://www.hobbyking.com/hobbyking/store/__8357__ZIPPY_Flightmax_4000mAh_2S1P_25C_Car_Lipoly_ROAR_Approved_.html
Thanks bro, will the bat's cable location be a problem if fitted on cc01, it is facing upright, not like the normal bat which are all at the side.
Any CC01 owner that can confirm this thingy? Or else buy already sala Thanks
RJNG- Crawler
RJNG wrote:qks57 wrote:http://www.hobbyking.com/hobbyking/store/__8357__ZIPPY_Flightmax_4000mAh_2S1P_25C_Car_Lipoly_ROAR_Approved_.html
i bring my turnigy 4000mah during the next trail for you to try the size and fit...
it fits into my df03ra...
boolean21 wrote:RJNG wrote:qks57 wrote:http://www.hobbyking.com/hobbyking/store/__8357__ZIPPY_Flightmax_4000mAh_2S1P_25C_Car_Lipoly_ROAR_Approved_.html
Thanks bro, got no battery also cannot trail.... sigh....
RJNG- Crawler
By the way, roughly how many bat you guy use for a single trail? This will detemine how many i need to buy. heh...
RJNG- Crawler
I bring spare batteries for you this coming Sunday if you are available to trail.RJNG wrote:Thanks bro, got no battery also cannot trail.... sigh....
usually 2 or 3 more than enough... depending on the trail location...RJNG wrote:By the way, roughly how many bat you guy use for a single trail? This will detemine how many i need to buy. heh...
boolean21 wrote:I bring spare batteries for you this coming Sunday if you are available to trail.RJNG wrote:Thanks bro, got no battery also cannot trail.... sigh....usually 2 or 3 more than enough... depending on the trail location...RJNG wrote:By the way, roughly how many bat you guy use for a single trail? This will detemine how many i need to buy. heh...
Thanks bro, how i wish i can trail soon, but i can only do it on an ad-hoc basic. My trail time mostly only be on a pubile hoilday. Sat and Sunday are burn for me. But again, still mostly ad-hoc, case to case. Hope you guy don't mind?
RJNG- Crawler
No problem bro...RJNG wrote:boolean21 wrote:I bring spare batteries for you this coming Sunday if you are available to trail.RJNG wrote:Thanks bro, got no battery also cannot trail.... sigh....usually 2 or 3 more than enough... depending on the trail location...RJNG wrote:By the way, roughly how many bat you guy use for a single trail? This will detemine how many i need to buy. heh...
Everyone have different schedules
Just join in whenever you free lor...
RJNG wrote:Thanks bro, will the bat's cable location be a problem if fitted on cc01, it is facing upright, not like the normal bat which are all at the side.
u're right.. for the M03 the battery holder has a hole in the middle, usually i'll plug in the cables after i lock the battery in.. not sure about the CC01's..
qks57 wrote:RJNG wrote:Thanks bro, will the bat's cable location be a problem if fitted on cc01, it is facing upright, not like the normal bat which are all at the side.
Thanks bro, looks like i might need to wait for some owner for cc01 to advise.
RJNG- Crawler
The turnigy 4000mah soft pack confirmed cannot fit CC-01. The pack qks57 mentioned is a hardcase but thicker pack can fit cos dimension shorter than the soft pack.
I`m using the rhino 1750mah 2S compact lipo on my CC-01, and can trail for 2~3 hrs as CC-01 dosent drain much juice, and that`s good enough! Last time on my highlift lasts around 45min to 1 hr max. You can also choose the 2200mah Turnigy soft packs if you wish... Hoped this helps!
Marpek wrote:qks57 wrote:RJNG wrote:Thanks bro, will the bat's cable location be a problem if fitted on cc01, it is facing upright, not like the normal bat which are all at the side.
Wow, this is great, ok i will look for Turnigy soft packs. Thanks again for all the helps and advises.
RJNG- Crawler
Dun buy Yeah racing packs. My yeah racing lipo bloated in just 3 months and TX pack one dead cell.
RTECH wrote: Dun buy Yeah racing packs. My yeah racing lipo bloated in just 3 months and TX pack one dead cell.
Roger that, thanks
RJNG- Crawler
Guys, i did some research on the lipo battery, boy... sound so scary. Wrong charge or mis-use it and the thing can catch fire or explode.
Any comment on this or any guys got advise. Is it that serious? Thanks
RJNG- Crawler
its not that scary.. i myself have been using them for more than 2 yrs with no such things happening..
qks57 wrote:its not that scary.. i myself have been using them for more than 2 yrs with no such things happening..
Thanks bro, think when I received my lipo, I do my charging outside the house just incase since this is my first time using. Still not similar with all those power rating.
RJNG- Crawler
haha i can understand your concern. if you're really afraid, you can get a lipo charging bag. it will ensure the safety of your home.
ya man... lipos are very dangerous if not treated properly... just get a lipo charger and dont leave it to charge overnight...
boolean21 wrote:ya man... lipos are very dangerous if not treated properly... just get a lipo charger and dont leave it to charge overnight...
Noted with thanks, cheers
RJNG- Crawler
qks57 wrote:haha i can understand your concern. if you're really afraid, you can get a lipo charging bag. it will ensure the safety of your home.
If you want, you can borrow from rtech, as he has the bag...coz he boji!
But dun be afraid, not that jialat one. If you sway, how you wanna prevent accident also cannot, even tho if you got the best chargers or prevention measures taken. Just like our homes we lived in, have electric, gas cookers, etc. All are machiam hazards rite, but you also sleep like a at nite until song song sibo?
RJNG wrote:Marpek wrote:qks57 wrote:RJNG wrote:Thanks bro, will the bat's cable location be a problem if fitted on cc01, it is facing upright, not like the normal bat which are all at the side.
Bro, remember to get low mah ones like 2400mah and below...
Marpek wrote:qks57 wrote:haha i can understand your concern. if you're really afraid, you can get a lipo charging bag. it will ensure the safety of your home.
True and well said.
RJNG- Crawler
Page 1 of 2 • 1, 2
» Monitoring LiPo Batteries and LiPo Safety
» cheap as chips x6
» Recommendations for cheap ESC with drag brake?
» Cheap Otar clone...and many more!
» Good day mate
» cheap as chips x6
» Good day mate
