Question and answer on electrical stuff.
Hi all, anyone know can we use boat esc on our crawler or car? Here is one, can I use it on my crawler? Many thanks
Here the link:http://www.r2hobbies.com/eng/proddetail.php?prod=rcps61604
Re: Question and answer on electrical stuff.
One more question, can I charge a 8000mah lipo with 5amp of power? Cause my charger current is max 5Amp only. Will it spoilt the battery or what?
ket2175 wrote:Hi all, anyone know can we use boat esc on our crawler or car? Here is one, can I use it on my crawler? Many thanks
I got 2 of these...
one unit shorted out before even running... havent tried the other one...
free replacement on the way....
short likely caused by the connectors I guess... better swap out with deans before trying....
will try them out in my next project...
ket2175 wrote:One more question, can I charge a 8000mah lipo with 5amp of power? Cause my charger current is max 5Amp only. Will it spoilt the battery or what?
Knn, 8000mah!!!!
If your battery is MH or ni-cd, can tahan 2C charge that is 16 amps.
If your battery is lipo, can tahan 1C charge that is 8 amps.
Your charger can charge only 5 amps nia. Your battery will be sleeping ....Zzzzz when you charge at 5 amps.
But your charger will be "knn how come so long the battery haven't full charge, nabey"
boolean21 wrote:ket2175 wrote:Hi all, anyone know can we use boat esc on our crawler or car? Here is one, can I use it on my crawler? Many thanks
I got 2 of these...
Ok will do so, but look like there is no (ON/OFF) switch. And there say water resistance is it true?
RTECH wrote:ket2175 wrote:One more question, can I charge a 8000mah lipo with 5amp of power? Cause my charger current is max 5Amp only. Will it spoilt the battery or what?
Knn, 8000mah!!!!
OIC but my charger I think cheap scape one , cause only have AMP no C leh?
8000 mah battery good sia hehe.
ket2175 wrote:RTECH wrote:ket2175 wrote:One more question, can I charge a 8000mah lipo with 5amp of power? Cause my charger current is max 5Amp only. Will it spoilt the battery or what?
Knn, 8000mah!!!!
C is the amps of the battery able to produce in one hour. Your battery 8000mah is 8 amps.
If 4000mah is 4 amps. Charge at 2C means 2 X 8 amps = 16 amps for 8000mah battery.
wow like very deep leh , me catch no ball. But anyway thanks RTECH.
Look like Boolean boat esc is cheap and good.
Nevermind, just charge at 5 amps can liao.ket2175 wrote:wow like very deep leh , me catch no ball. But anyway thanks RTECH.
RTECH wrote:Nevermind, just charge at 5 amps can liao.ket2175 wrote:wow like very deep leh , me catch no ball. But anyway thanks RTECH.
No lah I just say say only, cause 8000 mah battery also cant fit in my Summit too fat liao. Think 5000 mah just nice.
RTECH: Next week I need your help, cause I have a ON/OFF switch and I wanted to fix in my Wraith. So I need to know , which side is +/- . So that I can do soldering myself.
ket2175 wrote:RTECH: Next week I need your help, cause I have a ON/OFF switch and I wanted to fix in my Wraith. So I need to know , which side is +/- . So that I can do soldering myself.
Switch dun have +/- lah. Any direction also can.
RTECH wrote:ket2175 wrote:RTECH: Next week I need your help, cause I have a ON/OFF switch and I wanted to fix in my Wraith. So I need to know , which side is +/- . So that I can do soldering myself.
Below the switch got 3 legs coming out for u to solder wire to it , So as u say any direction also can. Thats mean I solder the first leg and the third leg , or first and second leg? Pls advice , many thanks.
ket2175 wrote:RTECH wrote:ket2175 wrote:RTECH: Next week I need your help, cause I have a ON/OFF switch and I wanted to fix in my Wraith. So I need to know , which side is +/- . So that I can do soldering myself.
usually three legs, the middle one is the common, solder one end to the middle, and solder the other end to either side.... just use a multimeter to verify...
boolean21 wrote:ket2175 wrote:RTECH wrote:ket2175 wrote:RTECH: Next week I need your help, cause I have a ON/OFF switch and I wanted to fix in my Wraith. So I need to know , which side is +/- . So that I can do soldering myself.
ok noted with thanks, will try when my Wraith come.
How come you buy the 3 leg one? Got 2 leg one smaller.
I mean the wire any direction also can, no +/-.
RTECH wrote:ket2175 wrote:RTECH wrote:ket2175 wrote:RTECH: Next week I need your help, cause I have a ON/OFF switch and I wanted to fix in my Wraith. So I need to know , which side is +/- . So that I can do soldering myself.
Last time buy one lor, no know so anyhow buy lor. U also dont want to teach, so no choice I suck suck thumbs lor.
Wow...
Somebody bought wraith liao ah....lai lai lai join the force
Harakiri- Boss
Harakiri wrote:Wow...
Still waiting for it to come.
» HOW STUFF WORKS!
» How to buy stuff from RC4WD?
» Where do you guys get the crawling stuff in SG?
» china website for all stuff RC
» Battery & Charger Question
