Boolean21's Land Rover Defender D90 Build....
+7
11 posters
Page 1 of 5
Page 1 of 5 • 1, 2, 3, 4, 5
here's my updates of the D90...
got 2 helpers to help build my land rover.... but... but... they only wayang wayang only.... using eye power... didn't help much....
here are the stuffs from rcmart....
and my 2 helpers demonstrating eye power!
ordered a r2 transmission for the build.... still contemplating whether to get the topcad axles or use my ax10 axles....
chassis will be build using the aluminium angle bars....
sketch up the frame already, just need to fine tune a bit before starting on the cutting....
Re: Boolean21's Land Rover Defender D90 Build....
Can't wait... use the force!
really looking forward to the D90 trail man!!!
the rest of the D90 owners... post some updates too bros!!
ahh... maybe we should create a D90 sub-section to group all the D90 stuffs inside there... if there are more D90 update threads...
post post post... photos photos photos!!
Some updates....
2 nights of work just to get this simple frame up....
i'm a slow worker....
now waiting for the R2 transmission to come and then finalize the frame... and cut the brackets for the body, bumper and side steps... then links... painting... etc etc etc....
still long way to go man....
some photos....
some photos....
Looks good man!
From the status from your pics, can see still a long way to go man. After you finished the chassis, planning the shell to fit nicely, and lastly painting the shell in details is another long lasting project...trust me!
may the force be with you...
Marpek wrote:Looks good man!
ya man... long long way to go!....
but december quite free!! i only work 9 days in Dec!...
so if anyone wanna trail in Dec during weekdays, let me know! i will join in if i can!
will channel some time into this project... will try to complete in Dec!
can't wait to go for the defender trail man!!
Bro...can wait, can wait...slowly man! Haha...
Boo, why dun you use bolts and nuts? Rivets will become loose if encounter hard impact and cannot be tighten. You got to drill it out and rivet again.
RTECH wrote:Boo, why dun you use bolts and nuts? Rivets will become loose if encounter hard impact and cannot be tighten. You got to drill it out and rivet again.
Ya, man... Thats my worry too... Will likely still them out and replace with bolt and nuts....
boolean21 wrote:RTECH wrote:Boo, why dun you use bolts and nuts? Rivets will become loose if encounter hard impact and cannot be tighten. You got to drill it out and rivet again.
din noticed you use riverts...kinda innovative sia! Next time invest stainless steel riverts...might look coo and strong, and may even hold better than bolts and nuts!
Why you guys din experience using solid alu rectangular bars to form the chassis by bending the profile? If i plan to custom a chassis like you guys, i will try that out! A rectangular profile similar to scx10 chassis should be able to do it... else use mild steel, but must heat treat.
Marpek wrote:boolean21 wrote:RTECH wrote:Boo, why dun you use bolts and nuts? Rivets will become loose if encounter hard impact and cannot be tighten. You got to drill it out and rivet again.
I saw people using square tubes and cut into half, length wise.... And became 2.C-channels... Then heat up with blow torch and clamp onto vice and bend like the scx10 chassis rails...
I can try to dig out the thread if anyone needs info...
Alu are easy to cut , But easily bent. Stainless steel is strong but difficult to cut. Mild steel slightly easy to cut not so easy to bent but will rust.
So wat metals to use........
I think aluminium is good enough man... Strong enough... No problem...
And most importantly, easy to work with....
Updates on the chassis...
Removed my axles from my ax10.... Drive shaft's grub screws were stuck... So drilled out the grub screws....
Drilled out rivets on the chassis as well and replaced them with bolts and nuts....
Mounted up the axles with the ax10 upper links... Shocks.... And mocked up the body... Need to lengthen the front links, and shorten the rear....
will think about it again.... Seems like goiod progress for one afternoon...
The rest of the defender builds, update your photos in your build threads too!
Here's some photos....
Nice jod shot have ask u to do another set to sell me
Thanks bro, but mine are rough cuts.... Not sale quality ones la... only good enough for own usage...Teck wrote:Nice jod shot have ask u to do another set to sell me
Haha Chinese got a saiding don't care white cat or black cat can caught rat is a good cat .rough or smooth cut I don't care as long as I can put on the landy is good enough haha anyway I have order the scx10 chassis hope I can do a nice jod too
Post your build thread too!Teck wrote:Haha Chinese got a saiding don't care white cat or black cat can caught rat is a good cat .rough or smooth cut I don't care as long as I can put on the landy is good enough haha anyway I have order the scx10 chassis hope I can do a nice jod too
Some updates...
The r2 transmission came!
Mounted it up liao....
Now need to cut a few more brackets to support the frame...
some photos here...
some photos here...
Look awesome , must have spend countless of hours and hard work on it. Thumbs up for u.
quick, quick, quick. When can your landy roll?
RTECH wrote: quick, quick, quick. When can your landy roll?
Bro interested to diy one also?
ket2175 wrote:RTECH wrote: quick, quick, quick. When can your landy roll?
Haha... no lah. I dun have the mood to DIY. I only like to see DIY trucks.
thanks bro, actually diy very shiok.... See the truck bring build up... Very interesting....ket2175 wrote:Look awesome , must have spend countless of hours and hard work on it. Thumbs up for u.
Now can roll liao... Haha... Can only roll... Nothing else....RTECH wrote: quick, quick, quick. When can your landy roll?
Wow.. .. doing Very fast liao
Then soon can do Land Rover Outing video liao
Swee! Wonder what color you decided to go with?
Btw, are those tyres from hongkong too? Looks similar to mine, but seems larger...
slow wrote:Wow.. .. doing Very fast liao
talking about video outing... bro eatdirt suggest tampines trail, me suggest ubin...bro slow lagi fierce suggest batam!
Trying to complete by Dec... Can't wait for the defender trail.... And also looking forward to the others' build thread leh....slow wrote:Wow.. .. doing Very fast liao
I also don't know what colour leh....Marpek wrote:Swee! Wonder what color you decided to go with?
Thinking of eatdirt's previous land rover colour, the 2 tone one.... Or bright yellow or bright orange.... Maybe light sand.....
U think light sand same colour as the unpainted shell?
If same, I just spray the front windscreen! Haha
Ya, the wheels and tyres are from topcad hongkong...
I think all 3 locations are great! lets do all 3!Marpek wrote:slow wrote:Wow.. .. doing Very fast liao
Found a photo of a land rover defender on 40 inch tyres and 2 inch body lift....
In comparison, our tyres don't look too oversized...
RTECH wrote:ket2175 wrote:RTECH wrote: quick, quick, quick. When can your landy roll?
Haha same as me.
» Slow Build Land Rover D90
» [VIDEO] 25 Trucks beach Trail: 15 Land Rover Defender scx10 Trail Finder 2 Wraith hilux Tundra Land Cruiser
» wrigleys' SCX10 Landy Land Rover D90 build
» wyetuck88's Land Rover Series 2 SWB build thread
» AngMohKia looking for Land Rover Defender D90
Page 1 of 5
