In total there are 17 users online :: 0 Registered, 0 Hidden and 17 Guests None
My wraith run crazy!?
D.ong
Hi guys,
Anyone here encounter auto run reverse at full speed by itself when i switch off my remote control switch n when switch back on it stop??! Other than tis auto reverse, the esc signal still working well for it normal control. Is tis telling me the esc shock plug liao..? Going spoil soon?
D.ong- Crawler
Re: My wraith run crazy!?
Does your system have a "failsafe" mode? Maybe it is setup incorrectly that when "failsafe" engages it is currently incorrectly set to "full reverse"?
Have a look at your RC and ESC manual!
laneboysrc wrote:Does your system have a "failsafe" mode? Maybe it is setup incorrectly that when "failsafe" engages it is currently incorrectly set to "full reverse"?
Wah chim.. i bought it as RTR set, so got no idea of "failsafe'' mode. So guess got no way to do any reset on the esc.
D.ong- Crawler
D.ong wrote:laneboysrc wrote:Does your system have a "failsafe" mode? Maybe it is setup incorrectly that when "failsafe" engages it is currently incorrectly set to "full reverse"?
Its the receive... Check the manual on how to bind and set the failsafe...
the car must always be switched off first then followed by the transmitter. that's a basic of rc which i think we should still follow.
Hmmm... Tink will see you guys on sunday trail then advise me more of it.
Thanks!
Thanks!
D.ong- Crawler
boolean21 wrote:D.ong wrote:laneboysrc wrote:Does your system have a "failsafe" mode? Maybe it is setup incorrectly that when "failsafe" engages it is currently incorrectly set to "full reverse"?
Check on receiver signal light, reset failsafe mode follow wraith manual, spotted battery wire connector faulty n change new.. Finally done, no more auto reverse when remote off.. Will test run a longer test n hope tings in order..
Thanks for the advised!
D.ong- Crawler
Good to hear that, see u this Sunday. Hope my esc can come on time for this Sunday trail.
Here is the link for the cheap cheap China Esc.
D.ong take a look.
http://www.ebay.com.sg/itm/300669729577?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648#ht_3984wt_1156
D.ong take a look.
Thanks ket!ket2175 wrote:Here is the link for the cheap cheap China Esc.
D.ong take a look.
But not sure tis esc can use for my wraith with 7.4v li-po battery..
As for tis sunday trail, i will c how my tis two days test run first. If bo prbm i may try to go..
D.ong- Crawler
This esc can use lipo no problem , but I think need a low voltage alarm.
Sian.. Change new nosram esc n motor. But still the same, test run awhile only stop.. Guess receiver really short liao,, can allow to play awhile only..(abt 3mins).
Final item left to change, change receiver n remote...sigh. N hope after tis my wraith can run as
per normal.
Anyone here can advise on tis prbm, or suggest any brand n amt of new remote n receiver.
per normal.
D.ong- Crawler
The ax3 tx by axial can bind with Hobbyking GT3 rx. Costs about $10 shipped. However if you want to really get a new set of tx and rx, Hobbyking has this 3 channel GT-3 rx with LCD screen going for below $50 with rx but check for stock on their web page.
oic..
wat about anywhere local got sell,, is it very expensive or ex by abit if i buy new tx and rx? cos will b more direct n shorter the repair timing.
D.ong- Crawler
» Skate Parks Location (For bashing? Jumping? Doing crazy stuffs" :D )
» rebuilding my wraith - teck's wraith rebuild thread
» Boolean21's Axial Wraith build - Updates: New Paint scheme - Captain America's Axial Wraith
» [VIDEO] Part2: 12 Trucks Offroad Adventures M35A2 MAN KAT1 8x8 Trail Finder 2 D90 Unimog Wraith Ford Tundra The Rigs: 2x Tundra, 2x D90, 2x Unimog, Wraith, Trail Finder 2, Ford f350, Series 2, M35A2, MAN KAT1 8x8
» my wraith new look
