Building custom chassis help/advice/suggestion needed
I want to build a custom chassis so that I can build any truck on top of it. I have look around and found that buying an Axial SCX10 kit is still cheaper than custom make till I found this ARB SE Trex 60 front and rear plastic complete axel only cost $109.99 from TGN. Anyone has this? Any comment on this axel?
Re: Building custom chassis help/advice/suggestion needed
Look scale but without axle link , steering link , shock , transmition .....
Will cost much more then scx10 !
But if u want scale look this is the one ! Rc4wd gelande d90 chassis also use this ! Also got 79.90 t-Rex 60 !
Hi Liew. The 79.90 T rex 60 tech shows a shorter width in mm but both still shows 8" width. Very confuse. The 79.90 dun come with the 12mm hex and some parts for the setup of suspension and link.
Steering link can DIY just need to buy some extra item to link up. But the SCX Kit got a lot of spare things that I do not need. I'm still doing my calculation on costing.
Looking more for flexibility to just buy the L bracket to do up chassis whenever I change truck body. I ored have 2 SCX 10. Just need another for DIY project. Now considering to buy a 3rd SCX or custom.
T Rex 60 79.90 are same with 109 , only 109 got red arb cover n alu steering knuckle .
The scx10 spare some maybe can use on t Rex !
I looked at the t rex 60 before... If I remember correctly, the 109 ones come with the arb metal covers... The 70+ ones haave normal plastic covers...
The red arb ones will look great for a landy build or hilux build...
you still need a transmission, shafts, shocks, etc....
Build build build!
Build build build!
Yo Man.
For Axles you may want to look at the RC4WD TF2 Axles.. At USD90.00
http://www.rpphobby.com/product_p/sytf5.htm
And also many tear down parts for sales at RPP Hobby Salvage Yard.. ..
http://www.rpphobby.com/category_s/407.htm
BUY BUY BUY.. ..
Build Build Build.. ..
BUY BUY BUY.. ..
Liew wrote:T Rex 60 79.90 are same with 109 , only 109 got red arb cover n alu steering knuckle .
TGN site shows only the axle without the nuts and some other item included in the 109. so not sure if they do come as the site not so clear. The red arb cover looks really nice! SCX spare mostly are the body and left over parts. May be able to salvage some.
boolean21 wrote:I looked at the t rex 60 before... If I remember correctly, the 109 ones come with the arb metal covers... The 70+ ones haave normal plastic covers...
Build build build!
If the additional item comes to slightly higher than the scx is still considered OK. Cos I get the free hand of customization to build anything on top of it. I can have different wheel base at any time without having dependent on the scx chassis. L bracket is not expensive and still can do the job, like what you did on your build.
slow wrote:Yo Man.
BUY BUY BUY.. ..
Wow!. I should have look harder. Thanks for the info. Now got more choice. The SCX parts is so cheap? Is this a "while stock last"?
Wah...So anyone ordering anything from rpp? Can I share shipping with you?
I am ordering 2.2 tires. we can work out the details on pm!!!
wyetuck88 wrote:Wah...So anyone ordering anything from rpp? Can I share shipping with you?
Hi Bro. If you can wait than should not be a problem. As I'm still looking for the correct parts to fit. As you know I just started out and not sure if all parts I want will fit. Its a Rojak parts.
babyboy wrote:boolean21 wrote:I looked at the t rex 60 before... If I remember correctly, the 109 ones come with the arb metal covers... The 70+ ones haave normal plastic covers...
Build build build!
ya man... used 3mm thick L-brackets for 3 builds so far...
cheap and good... can consider 1mm thick L-brackets too... some of the bros use the 1mm thick ones still holding well...
yeah, it's the joy of building the truck from raw material and see it run... the feeling is priceless... i think when wyetuck see his metal landy offroading in the trails... he'll feel that all his effort is worthwhile!
looking forward to your next build thread babyboy.
boolean21 wrote:babyboy wrote:boolean21 wrote:I looked at the t rex 60 before... If I remember correctly, the 109 ones come with the arb metal covers... The 70+ ones haave normal plastic covers...
Build build build!
Thanks boolean21. I'm still learning to build. I'll build my second D110 but will be mostly picture all the way for my second SCX. So once finnish I'll upload all pic together from the beginning to the end. Now have to do some maintenance to the existing scx. Think have some minor problem with the front axel that do not have the same turning speed as the back axel. Need to open up and check.
Haha thanks boo! I am sure all of us share that same joy seeing our masterpiece slowly takes shape and finally completed and seeing it in action on the trail.
babyboy wrote:slow wrote:Yo Man.
BUY BUY BUY.. ..
It is base on while stock last, but the shipping to singapore is not cheap..
slow wrote:babyboy wrote:slow wrote:Yo Man.
BUY BUY BUY.. ..
Just did a simple purchase test. Item total USD$94.97 Shipping USD$54++ this is crazy. Sad think I'll look again..
» Buying Axial Honcho RTR--Advice Needed - DWJL511's SCX10 Honcho
» NEED HELP IN BUILDING RIG!!!
» Babyboy's Ford 15CWT on Custom Chassis
» Slow's Jeep Wrangler Build photos - AX10 with custom made scale chassis
» The Building of Trail Finder 2 - Zax13's TF2
