Slow LAND ROVER D90 SCX10
+5
EatDirT
9 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Finally, Slow Land Rover D90 is BUILD.. .. .. ..
Click on image to show larger photo.
Last edited by boolean21 on Mon 14 Nov 2011 - 16:39; edited 2 times in total (Reason for editing : Uploaded Photos)
Re: Slow LAND ROVER D90 SCX10
this slow..... really... is not slow at all man....
nice build! you changed a smaller spur?
like lots of cutting... painful....
should have asked you to trace out the scx10 frame before you fit up everything....
[quote="slow"]Finally, Slow Land Rover D90 is BUILD.. .. .. ..
SWEE....
when can go test drive ??
SWEE....
EatDirT- Crawler
Ooi , how come bo color one?
RTECH wrote: Ooi , how come bo color one?
Still WIP la
What colour to choose?????
boolean21 wrote:this slow..... really... is not slow at all man....
Me using the stock 87T spur gear.
As i putting the interior as low as posible, so needs to cut and trims here and there.. .. .. .. ..
[quote="EatDirT"]
Me tested at home liao.
Using Tamiya cheap ESC, Tamiya Dirt Tune motor ( 27T) and 2.2 lipo 2s.
It is working good.. .. ..
slow wrote:Finally, Slow Land Rover D90 is BUILD.. .. .. ..
SWEE....
Ooi, dun said tamiya esc is cheap! Its one of most reliable esc you can find, and can tahan some water without fail...
After some times.. .. .. .. ..
Some work in progress update.. .. .. ..
should be finishing soon.. .. ... .. ..
Last edited by boolean21 on Fri 2 Dec 2011 - 8:44; edited 1 time in total (Reason for editing : Added Photos)
Me used 1 can of white primer as base colour for whole Landy body, Both inside and outside Body.
Follow by 1 x Tamiya Pink TS-25 for external body, some Metallic Black TS-40 for the fander.
Lastly cover all whole Body with 1 can Tamiya Clear TS-13.
Faster ! faster ! faster ! finish. I wan to see ! see! see!
Trying very fast liao lei.. .. .. .. ..
But me SLOW la
But me SLOW la
Finally.... our pink panther landy finally revealed!!!!!!!!
slow wrote:After some times.. .. .. .. ..
bro, so hardworking ar...next time post some step by step pics of the machines you built during work also...
slow wrote:Yes Sir
Hahaha...joking nia lar!
I see 2 tua neh nehs... that yopek sure likes it!
This Pink Landy is Traillllll Proooooven.. .. .. ..
slow wrote:This Pink Landy is Traillllll Proooooven.. .. .. ..
so...wats your next project?
hi Slow, do u shorten the Front Links or the Rear Links to achieve the 278mm for the D90? Or u shorten both front and rear...
is your suspension still in upright position after you shorten?
seatbelt- Crawler
HI Bro
I just replace the Rear links with shorten links.
The Front one remain as 91mm.
For the rear, i am using 4-links. I used 80mm links for the rear lower links, and 70mm as the top links.
I had to drill/ relocate the rear suspension to the front.
Wa Say...... damn chio..... pretty ladies with BIG boobs....
Can I take her for a ride please.......... Most importantly, are the legs moveable?
dwong- Crawler
Wahahaha... U dirty old man!dwong wrote:Wa Say...... damn chio..... pretty ladies with BIG boobs....
seatbelt wrote:hi Slow, do u shorten the Front Links or the Rear Links to achieve the 278mm for the D90? Or u shorten both front and rear...
Hi Bro,
You might also like to refer to this site for some idea, it is quite detail I should said. Happy building.
http://www.pakistanrc.com/forum/brand-specific-kits/axial-scx10-crawler/project-land-rover-defender-d90-110-scale
RJNG- Crawler
Page 1 of 2 • 1, 2
» BabyBoy's Land Rover D110 on Axial SCX10
» Slow Build Land Rover D90
» wrigleys' SCX10 Landy Land Rover D90 build
» SCX10's - Land Rover Discovery & Tundra
» SCX10 - Land Rover Discovery 3. Can She Drive?
Page 1 of 2
