wrigleys' SCX10 Landy Land Rover D90 build
Basically I followed http://www.pakistanrc.com/forum/brand-specific-kits/axial-scx10-crawler/project-land-rover-defender-d90-110-scale (Bro Boo shared this thread).
Firstly to shorten the wheelbase, I removed the spacers on the front and back 3 links.
Next made the 4 lower links with M4 all thread plus HPI M4 rod links(got it from taising) and sleeved it with ID 5mm carbon tube (from Rotor Hobby)
Images courtesy of Babar from Pakistan RC.
Placed the spacer as such.
ESC ballooned up (for my case) and placed on top servo with velcro.
Battery on top of receiver box with velcro
Lastly cut the bottom for the spear gear.
Body sprayed with Tamiya British Green and fenders in Black.
Re: wrigleys' SCX10 Landy Land Rover D90 build
More pics more pics! Haha!
Looking forward to molest the fresh landy!
Whoah ! I see a high performance brushless system !
Hehe bro Rtech that pictures are not mine. I took it from pakistan rc as i didn't take pictures of mine as I followed almost the same build as the pakistan rc guy. Hehe.
Just some updates. Changed to AX10 shocks for more clearance. (Need to change shock oil for less flex or maybe change spring too.)
Placed the spare proline wheel at the back.
The spare wheel on top of the hood is just an idea. Most likely will remove it as it is an odd one out here.
If you got any ideas, please let me know so I can improve this vehicle.
Change to thicker oil as now your CG is higher to prevent the chassis from swing side to side too fast and topple.
Dun change the springs 1st, test with thicker oil and see. Harder springs will loose traction .
nice... now only left a few landies under construction...
Ya i feel it sits too high.. Ok will experiment with the setups..
Haha just to update with some pictures.
Btw, I changed to stock scx10 shocks to lower the body.. yet to take pics..
» respraying my landy - Teck's Land Rover Defender D90
» Wrigleys' SCX10 Dingo Kit Build (On a budget)
» Slow LAND ROVER D90 SCX10
» Slow Build Land Rover D90
» Boolean21's Land Rover Defender D90 Build....
