In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests :: 1 BotNone
» 4x4 Winter offroadby CraftRC Wed 18 Apr 2018 - 20:10
by boolean21 Sat 30 Dec 2017 - 16:16
by boolean21 Sat 2 Dec 2017 - 12:05
by boolean21 Sat 14 Oct 2017 - 8:54
by boolean21 Fri 6 Oct 2017 - 21:30
boolean21 |
RTECH |
gionata78 |
laneboysrc |
oceanic |
Marpek |
babyboy |
Wrigleys |
ShaiAX55 |
Grease question
Page 1 of 1 • Share •
Grease question
Can I buy normal grease for my SCX10 kit from hardware store or must get special grease. I bought one from LSH but says only good for metal gear and general for joint. Cos the one provided by the kit is patheticly very small amount and it's to be use everywhere and very sticky as compare to the one I bought. If I got high temp grease can I use it?(its machine grease and sticky)
Re: Grease question
You can also get the marine grease from jethobby... $10 for a tube.... Can use for quite some time....
Those thick automotive grease will work too... Use to have a big tube, but dunno where to buy liao...
So using marine grease now....
boolean21- Crawler
Re: Grease question
OK. Didn't know that jet hobby got sell marine grease...
Re: Grease question
i used to use automotive grease from castrol, those meant for timing belts and other belts for my gears and stuff..
Re: Grease question
Thanks qks57. How often you need to grease the gears in the axel?
Re: Grease question
i re-grease my gears every 3-6 months, depend on how often i play.
Marine Greasing the Axles for water proofing
Hi All,
Sorry to hi jack this thread, but I got a question about water proofing the SCX10 Axles. Saw tons of youtube videos about water proofing the SCX10 axles by filling the inside with marine grease.
Do any of you guys do that for water proofing? I ask because my axles are still not assembled. Once assembled, I do not think I would like to take it apart again later. So if filling it with marine grease is the way to go, I shall get a tube tomorrow, stuff it with grease before I continue with the assembly.
Thanks in advance for the inputs.
Cheers
Cheers
RCGolf- Crawler
Re: Grease question
I dun really stuff mine with marine grease. Only the gears. Water will seep in anyway. Dun know if any bros stuff theirs but will help to make your ride sound proof from the gears.
. Bro oceanic ride is the quietest from my observation and he says he used a lot of grease for the gears.
For me I will take it apart again for maintenance once I clock my mileage.
Re: Grease question
babyboy wrote:I dun really stuff mine with marine grease. Only the gears. Water will seep in anyway. Dun know if any bros stuff theirs but will help to make your ride sound proof from the gears.. Bro oceanic ride is the quietest from my observation and he says he used a lot of grease for the gears.
hahaha, no i dont grease the gears, i spray lubricants only. bro slow stuff marine grease in it, and his trucks is the silent ones. really silent man...
oceanic- Moderator
Re: Grease question
boolean21 wrote:You can also get the marine grease from jethobby... $10 for a tube.... Can use for quite some time....
Thanks Babyboy for the inputs. Called JetHooby and they do not have stock for the marine grease. Any one know where else i can get it?
Tks
RCGolf- Crawler
Re: Grease question
ya, their grease sold out....
they still have the same grease, but packaged with the injector... at $20+....
guess have to wait for them to restock...
no idea where else to get the marine grease...
wait for the other bros to see if they know of any other places.
boolean21- Crawler
Re: Grease question
Rcs or ntc also do sell the marine grease
Harakiri- Boss
Re: Grease question
tks for info, need to get the grease too as sooner or later got to waterproof. but just another side question, hope OP dun mind. Where to get proper set of hex screwdrivers for SCX10? I hv those L shaped hexes but those hard to use. Also, what mm sizes to get? So far hardware shops only sell Philips screwdrivers.
DWJL511- Crawler
Re: Grease question
you should be able to get them locally from most hobby shops...
if no hurry, get from hobbyking.... around usd4 for a set...
can get some batteries, spare receivers, etc from there at the same time.
boolean21- Crawler
Re: Grease question
Harakiri wrote:Rcs or ntc also do sell the marine grease
Thanks Harakiri for the input. Managed to get a tube of marine grease suitable for RC boating at RCS for $9.
RCGolf- Crawler
Re: Grease question
DWJL511 wrote:tks for info, need to get the grease too as sooner or later got to waterproof. but just another side question, hope OP dun mind. Where to get proper set of hex screwdrivers for SCX10? I hv those L shaped hexes but those hard to use. Also, what mm sizes to get? So far hardware shops only sell Philips screwdrivers.
size is 1.5, 2, 2.5
As wht Boolean said if can wait than online purchase. I bought each for about S$5 locally.
Re: Grease question
babyboy wrote:
size is 1.5, 2, 2.5
ok tks will look for them.
DWJL511- Crawler
» Grease question
» Question About Gladiator beasts.
» Dark Fusion / Mirror Force question
» Question about Reinforce Truth
» Question on scrap dragon
