wyetuck88's Land Rover Series 2 SWB build thread
+8
12 posters
Page 2 of 6
Page 2 of 6 • 1, 2, 3, 4, 5, 6
Re: wyetuck88's Land Rover Series 2 SWB build thread
Thanksoceanic wrote:Nicely done!
U mean the U joint? Bought it from ebay, sgd 12 per piece. Rod is 4mm in thickness.boolean21 wrote:yo bro...
where did you buy this?
the "yoke to yoke" adapter? is it a 5mm rod that you use to link up from the motor to the pinion?
thanks
Wah piang, very big job. Machiam like building a robot.
ah boo np!
haha yeah... should have done a small scale one...Nvm la first build. Learn from mistake loh....length of the body stands at 530mm now!!! Not sure how am i going to bring that shell to trail too weights at least 1.5 kg.
started to work on the face plate and some more mock up photo
the ride height will be adjusted when the whole body is finished. right now its sitting
on the tires.
on the tires.
A true armour vehicle!
Just amazing what you did with only mess tin. You are one great craftman man.... Good work!
RJNG- Crawler
thanks!boolean21 wrote:Nice updates!
haha I hope it still look like a land rover S2RTECH wrote:A true armour vehicle!
thank you!RJNG wrote:Just amazing what you did with only mess tin. You are one great craftman man.... Good work!
Thanks for the update, amazing job! Looks like an old Landy already.
Please keep posting updates!
laneboysrc wrote:Thanks for the update, amazing job! Looks like an old Landy already.
Thanks!!!!
Some update.
I re-draw a proper land rover Series 2 front view, and a series 3 back view.
Learn that building from Pics is not as accurate as building from blueprint.
Made the roof today.
Side view
internal view
Yes I know they are too long. I will do the cutting and trimming later.
Made the hood too!
front shot
top shot
side angle shot.
dont worry about all the rough edges and improper fit, they will be sorted out later
Made new left and right window panels too. the old ones are short of 4mm.
Not sure if I should make open-able doors? The curves are hard to cut. Most probably
need to laser cut, what are your opinions?
Nice work.
U made a jig to bend the roof and hood?
Nice bend job!
Nice bend job!
boolean21 wrote:Nice work.
Nice bend job!
nah its done by machine. 1mm thick aluminum is bendable but 2mm aluminum requires machine to do the job.
wyetuck88 wrote:boolean21 wrote:Nice work.
Nice bend job!
I see I see... Was about to ask u post photos of the jig...
Thought you carved a male and a female mold and clamp the aluminium between the molds to form the parts...
Rig is not ready la still need to make a new chassis. . need to make sure everything is finished properly then weld together then its counted as complete.
you will need a sheet metal brake press. you can DIY by using L shape brackets and a mini hydraulic jack.
err bro, ur hobby is steel bending ah?
nvr tot someone will actually do a steel series2 (scale)
i salute u, n e rest of e bros out here who fabricate their own scale bodies.
ironman wrote:err bro, ur hobby is steel bending ah?
Thanks! haha my hobby? nah, its a nice set of skill to have but not something I would want to do in my free time.
anyway some updates.
Picked up some 1 inch by 1 inch square rod and started working on the chassis
Bend and cut into half, and join together by nuts and some threaded screw
got some L brackets and more work on the chassis
currently like this, still got more work to do.
Thanks for reading!!!
Looks great! Thanks for sharing the details of how you did it. One day if time allows...
Wah !!!!!!
Nice metal work !
Nice metal work !
laneboysrc wrote:Looks great! Thanks for sharing the details of how you did it. One day if time allows...
Thanks, sure why not?
Liew wrote:Wah !!!!!!
Nice metal work !
Thanks!!!
Hi Bro did u bend the chassis yourself nice
ironman wrote:damn!!!! u're good!!!
Thanks!!! learning curve for me haha
Teck wrote:Hi Bro did u bend the chassis yourself nice
Thanks! Yes, I think out quite alright.
by hand ?wyetuck88 wrote:Teck wrote:Hi Bro did u bend the chassis yourself nice
Liew wrote:by hand ?wyetuck88 wrote:Teck wrote:Hi Bro did u bend the chassis yourself nice
hmm yes using my body weight and bending on the round balancing beam at the fitness corner at my park.
Haha good way to keep fit btw do u know of anyone or place that can help me make a motor mount for my boat want to make a water cool motor mount but don't know were to make
Haha,yeah six pack here i come!!!
you can try this place.
Wing Heng Iron Works Co. Pte Ltd
Address:
Kallang Basin Industrial Park #01-2634, 80 Geylang Bahru, (S)339688
Tel: 6292 1344
Look for ah hua.
Just need to draw out the dimension and tell him your design and he will be able to help you.
Address:
Tel: 6292 1344
Look for ah hua.
» Slow Build Land Rover D90
» Boolean21's Land Rover Defender D90 Build....
» wrigleys' SCX10 Landy Land Rover D90 build
» [BUILD THREAD] Boolean21's Realacc x210 build diary
» Boolean21's Axial XR10 build thread
Page 2 of 6
